Hiding cables from a wall mounted plasma
Heifetz
I'm not planning to cut holes to run the cables down my wall because I live in an apt. Does anyone here have any suggestions on what I can buy to hide the cables running down the plasma?
RagingBITCH
17,618
Wall colored cable coupling. Or you could get a small wall colored board to mount flush against the wall/under the tv so it hides all the wiring.
giantpinkbunnyhead
3,251
Before I ran mine through the wall, I had a nasty bundle of wires that was always visible. But to clean it up, I bought several feet of split loom and stuffed the wires into that. Looked much better... then I further was able to decorate the area around my TV such that the split loom was hidden. I had a potted plant that covered it quite nicely.
lozina
11,711
8
Buy more plasma TVs and tile them on the wall on top of eachother so there is wall shwoing between them. That oughta do it. yeah.
