Hidden drive-space problem
jvarszegi
721
I just got issued a new Thinkpad T41 at work, and it has a Fujitsu MHT2040AH drive. When I received the machine I noticed that it was reporting only around 33 gigs of space in Windows Explorer, which seemed like an odd number. I searched on the part number and found out that this is a 40-gig drive. I thought maybe there was a hidden system-restore partition installed by IBM, but if there is Partition Magic doesn't see it. Any idea what the problem could be? Is there maybe some hidden auditing software on my machine that even Partition Magic can't see? The guy who set the machine up, who sits near me at work, disavows any knowledge of where the missing space could've gone. Here's what System Information reports:
Description Disk drive
Manufacturer (Standard disk drives)
Model FUJITSU MHT2040AH
Bytes/Sector 512
Media Loaded Yes
Media Type Fixed hard disk
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 0
SCSI Target ID 0
Sectors/Track 63
Size 33.86 GB (36,361,543,680 bytes)
Total Cylinders 4,697
Total Sectors 71,018,640
Total Tracks 1,127,280
Tracks/Cylinder 240
Partition Disk #0, Partition #0
Partition Size 25.00 GB (26,847,281,664 bytes)
Partition Starting Offset 32,256 bytes
Partition Disk #0, Partition #1
Partition Size 8.86 GB (9,514,229,760 bytes)
Partition Starting Offset 26,847,313,920 bytes
I made the second partition myself after installing Partition Magic on the machine, but the totals are still basically the same. Thanks.
jvarszegi
721
xcrunner51, thanks a lot for your help. Forgive me for such a simple question. I did Google around a bit, but wasn't finding anything; if I weren't such a dumbass about Windows admin stuff I would've thought to look in the BIOS settings. It worked perfectly.
