- Mar 18, 2003
- 1,198
- 1
- 71
Okay, apparently this one part is going to be my white whale. I've got a 2003 Infiniti Q45 that had a ballast go out on the driver's side HID headlamp assembly. I've changed the bulb and still no light. I've tested the ballast and it turned out dead.
My google-fu and other search abilities are coming up dead as well. Maybe someone on here can help.
I see many search results come back with ballasts that are described as 'compatable' but it appears to me the connector is different. Would I just be able to cut old wires and solder the new pigtail connector on for the new ballast as long as the ratings are the same?
I don't mind putting another after-market ballast on even if some cutting of wires and re-locating of the ballast is necessary.
