Hibernation and Stand-By gone in XP Pro
Snoozy
45
Somehow, I managed to disable Stand-By and Hibernation on my Laptop running XP Pro. I want the system to go into stand-by when I shut the lid, however its not an option anywhere. I can't even go to start -> shutdown -> stand-by (or hibernate)!
I have xteq installed, and I might have done it there (can't remember), but when I root around in xteq I can't find a place where that is even an option. Any ideas on how to enable stand-by and hibernation?
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
Originally posted by: QTPie
At the shutdown window, hold down CTR + SHIFT to get HIBERNATE.
Please read the question, he has neither standby or hibernate enabled on the system (for some reason). Also, for the record, you hold 'shift' to get hiberntate, no need to also hold control.
Bill
jazzhound
Banned
Mar 7, 2001
584
I don't quite understand this. Are you saying the options have disappeared in PowerManagement or just the Shutdown menu?
Look under Power Scheme tab in Power Options in Control Panel. I don't know how to access it through system via My computer right click.
XP installs differently on laptops then desktops; I've advised you through the scheme of a laptop install.
QTPie
1,813
Originally posted by: bsobel Please read the question, he has neither standby or hibernate enabled on the system (for some reason). Also, for the record, you hold 'shift' to get hiberntate, no need to also hold control.
Bill
ScrapSilicon already answered the question: PowerManagement(XP ..Power Options..Advanced tab..?)..?
Thank for the info.
If the option disappeared in PowerManagement , probably ACPI and Power Management in the BIOS is disabled. But that's unlikely.
bsobel
Dec 9, 2001
13,346
Thank for the info.
That would explain Hibernate being gone, but not standby....
Bill
andrey
Snoozy,
Have you ever tried to upgrade/install/uninstall video drivers on your laptop? In many instances incorrectly installed video drivers will disable both Standby and Hibernate options. Just something to check...
