Hi I Need help ocing my 2.26b + p4s533
snerdy
Hi, I just ordered a p4s533, 2.26b, corsair xms 3200 256mb.
I want to know what should i set the fsb, mem ratio, and voltage, if i wanted to get between 2.8-3.0 ghz oc. I need some explaining about the agp/pci frequency problem that asus has. I heard that when you go above fsb 133, you increases your agp/pci frequency. Is this bad? Would it affect my gaming performance?
1 more question how many of you can do 160 fsb on a 2.26b stable?
Thank you
Mikki
1,488
There's a ton of info here, lot's of threads with setups just like yours. Dive in and start reading! :)
Check out the overclocking sites like overclocker.com, etc.
Good luck! ;)
