This archive contains the latest version (June 2025) of all VCRedist Visual Studio C++ runtimes, installable with a single click by running the inclu
www.techpowerup.com
That was one of my favorite little discoveries, and one of the first things I install these days. That + chipset and GPU drivers + DirectX (for DX9 and legacy titles) gets you basically home free for a new build out.
OP, do you have any spare drives you could hook up in place of your current one? Unless you have an enormously terrible PC or old dying HDD, installing a test install of Windows (get the new v1909 by googling 'Windows 10 ISO', run the little USB builder tool from MS, and install a clean UEFI OS to double check with. End to end this is like 15 minutes of work.
If everything is running fine with a clean install, then your software was borked somehow previously. If it still does the same thing, you may have some odd gremlins somewhere.
Games require the GPU to ramp up from basically idling in 2D UI, to much more demanding power use and heat output. Although it doesn't sound like this is precisely the case you're having, it can't be immediately ruled out either.
As always, process of elimination is key :
AIO Visual C pack will take care of that
DirectX update
GPU driver
Chipset driver (not entirely necessary with some builds, but I do this anyway haha)
Windows updates.
Any critical AGESA or firmware updates as required.
Double check BIOS configuration and reported power measurements. +12V, +5V, +3.3V should be nominally in those ranges.
Depending on Mobo you can disable XMP and manually spec out a loosey goosey lazy clock to rule out borderline ram.
If you have an integrated or spare GPU to use, even if it's fairly awful, it is still enough to test and rule out that component.
Ditto checking out alternative power supply if you have one handy or a willing buddy in the area to supply something usable to cross that off your list.
After all of that, then you're left with CPU and/or Mobo. Which is far less fun or easy for most people to come up with a matching spare to do that level of process of elimination. But we could cross that bridge after literally everything else is ruled out : clean OS, alternative HDD or SSD, basic Ram timings and default Mobo settings, and so on.
All this sounds big, but if you make a list and run it down, you should be through the entire component and platform process of elimination in under an hour.
