I put a new CPU cooler on my computer, and apparently picked the wrong 80mm fan. At high RPM it not only sounds like a jet engine
but vibrates too. (Not good for a CPU.)
Can someone recommend a high flow 90/92mm fan that is also quiet? Most important is that it doesn't vibrate more than anything--it won't be running at full speed all of the time anyway.
Maybe I go for my electronics catalog and find a Papst or Ball Bearing Panasonic for example. Something not made in China.
Thanks!
Thanks!
