Hi first gaming pc need some help!
cmagee511
Hi I am looking to build a gaming pc and I was just wonder If I could get and over view on this build I have put together. I not an expert on doing this so I would like some help.
http://uk.pcpartpicker.com/p/3EoIp This link will show the parts I have put together.
Would like some feedback if the parts will work or even run games at a good rate.:\:\
Let me see how many of [thread=80121]the questions[/thread] I can fill in for you:
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming. Anything else?
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
£500-ish?
3. What country YOU will be buying YOUR parts from.
UK
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
None???
7. IF YOU plan on overclocking or run the system at default speeds.
Default speeds???
8. What resolution, not monitor size, will you be using?
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
No???
If you're not doing anything but gaming on this, I'd drop the SSD. Then you have more money for a better PSU, GPU, and CPU.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor (£137.99 @ Aria PC)
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard (£35.84 @ Amazon UK)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory (£55.08 @ Ebuyer)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£33.59 @ Aria PC)
Video Card: XFX Radeon R9 270X 2GB Double Dissipation Video Card (£139.99 @ Aria PC)
Case: Cooler Master N200 MicroATX Mid Tower Case (£31.73 @ CCL Computers)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (£44.14 @ CCL Computers)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£11.98 @ Scan.co.uk)
Total: £490.34
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-05 20:25 BST+0100)
Note: Faster RAM isn't usually useful, but this stuff was on sale. 🙂
A SSD works very well with games, even if gaming would be the only thing you will do on it (which I doubt), it would still be a good idea to get one imo.
Moving on, the G.Skill Ripjaws are excellent and the 270X is also a better choice than the 750Ti, though you might want to look into the differences between all the different brands.
Gaming,Coursework/Homework for school and general stuff
£500-ish? budget is around 500-600
UK and any other places that sell cheap parts
??? I don't mind what brand it is.
Don't have any old parts this will be my first pc.
Don't plan on overclocking
22inch 1920 x 1080 is the highest resolution on the monitor
Couple of weeks when I get the right parts together
No
Doing other stuff makes an SSD very appealing. You can easily add an SSD to my build for under £550 total.
What games are you playing? It might be worthwhile to step up the video card another notch and bring the build closer to £600.
Total: £490.34
Given a budget that can stretch closer to £600, I'd take Ken's build and add a Crucial M500 120GB for £53.
The game I mostly play is league of legends but I would like to try playing call of duty etc. Thanks for the help
