- Jan 16, 2001
- 31,528
- 3
- 76
OK guys, it's done. And it will be getting REDONE this weekend.
The actual mounting of branch to stone is flawless, IMHO, but the size of the stone is too small...I screwed up and broke it wrong...
As the stone comes, it's 12x12 and way too heavy to sit on a glass-bottomed tank. So, I tried to break it in two even pieces. What an idiot I am.
I broke it in thirds, basically. I grabbed the biggest piece and used that.
Due to the base (stone) being a little on the small side, the whole thing is a bit tippy when weight is applied to the uppermost branches. Kinda defeats the purpose, you know? But, it's in the tank and she's climbed on it already, w/no ill effects. But, when I do something, it has to be perfect, so I'll be redoing it this weekend. Should take all of 30 minutes, assuming I don't screw it up agian.
*Shut up, Mike and give us pics!!!!!* OK, fine.
Here's the branch, before mounting You can see the bolt in the bottom.
Closeup of the hangar bolt screwed into the branch. I used the nut to get a grip on it
Countersunk hole in bottom, before mounting branch The big hole is 3/4 inch, the small, 1/4 inch slightly "enlarged" by wiggling the bit a little bit.
Pic of the branch mounted. You can see how the nut is countersunk!
The finished product
Here is the BRB sleeping
Here she is on the branch!!! Mission is a success!! (sorta)
*EDITED AGAIN FOR MORE PICS*
OK, maybe it won't topple after all
Tell me she's not beautiful!
___________________________________________________________________________________________________________________________________________
I know the subject is confusing.
Here's what I'm doing; I'm taking a small tree branch, and bolting it to a 12" x 12" piece of paving stone. You know, the kind they sell at Home Depot to make driveways and such. I'm making a climbing branch for one of my snakes. Basically, the end of the branch is sawn-off flat, and I need to bolt it, upright, to the stone.
I plan on using a hangar bolt to do this; it has one end w/screw threads to screw into wood, the other end is threaded for a nut. HANGAR BOLT
Obviously, the nut that will be holding the branch on has to be recessed into the bottom of the stone, otherwise the stone won't sit flat.
So, how do I make the hole big enough for the nut to sit in? Use a second drill bit that makes a hole big enough for the nut?
I hope my description is descriptive enough...thanks.
