HEY, How can I put in my own color codes for forum
monzi
I used to be able to have my own THEME for this site.
My own Color codes for backrounds, and such.
I WANT THEM BACK. I dont like the current themes.
I want to be able to change the WHITE anandtech backround to
my own DESIRE. Give it back.
-Monzi
-Monzi
I have to agree, the white is just too bright. I used to have mine set to a black background which to me was so much easier on my eyes. Hopefully once they get some of the other minor bugs worked out they will turn the feature back on.
There are no color customizations available due to an architecture shift in CSS style sheets that cannot be modified at runtime.
Sorry.
I want the old forums back.
Have BOTH RUNNING using the same user database and post DB
This is OBSERD.
http://forums.anandtech.com
and
http://classic.anandtech.com
To be blunt, I dont like this.
My favorite forum has turned into something
un-manageable-and un-astehicly pritty (if that makes any sense/ignore the butchering of spelling)
Anandtech is loosing its fame. Bring it back to the top.
-monzi
If your enjoyment of a forum meant for discussion hinges on how it looks, then you have more problems than a color change will fix.
Sorry.
Style sheets might not be able to be "modified" at runtime, but I'm sure they can be overridden at runtime.
Would it be possible, once things shake out with the new upgrade, to have another dark theme, or to change the one that you already have? I realy don't like the one that's there now. I used the color customizations to alter the way the old theme looked to the way I wanted it.
