Hey guys help me
*GameOver*
hey ı am dont english please help me.
ı am using Asus HD7850 Directcu II
my problem black screen and dont working zero core.
my screen sleep minutes 10 and my screen sleeping and dont working zero core
my screen sleep minute 1 and my screen sleeping and zero core no problem. 4 minutes later and auto and re-awakening 🙁 and dont working zero core
ı am bios update and full windows format and change OS Everything up to date, but still did not improve
Please help I'm going to do what I did everything I did not get fixed.
my system
Asus M5A99X Evo R2.0
Asus HD7850 2GB 256Bit Direct X 11.1 860Mhz/4800Mhz
Corsair 2x4Gb 1600Mhz CL9
Amd Fx6300 3.5Ghz 6 Core (Overclocked 4.0Ghz)
HAF 912+ 750W 80Plus
WD 1TB 7200Rpm HDD Blue
Language Update please read.
this is my graphics card's problem
I set the screen off setting is 1 minute and the screen turns off after 1 minute.Also zerocore comes in and graphics card's fans are stop but after 5 minutes the graphics cards being work spontaneously and the monitor wakes up immediately.Then the screen sleeps againg but this time cards doesnt. Cards still work.
if i setting the turn off monitor 10 minute i dont have a problem like that.
After 10 minutes monitor is turn of and until i touch its sleep. But the cards never sleeps.I threw formats many times.I update the bios.
Finally i use amd driver and i still cant figure out.
You already tried changing the drivers I assume? Also, do you have another video card on hand that you can test to make sure it's not a hardware issue?
I think he said the problem was that when the screen is powered down in Windows it doesn't stay asleep for more than 10 minutes, it wakes up on its own without user intervention. In addition to that it sounds like when the screen is off sometimes AMDs no power draw mode isn't working, the GPU is still pulling significant power.
Carfax83
No other graphics card
refresh the whole thing.
I threw format
I update the bios
but did not improve
Jaydip
Yes, you heard me.
sleep does not work properly
http://j1307.hizliresim.com/1c/u/qtw0n.jpg < screen shot
my problem piece by piece
I write becomes smoother
particularly the monitor sleep setting 1 minute;
After 1 minute, but it fits the monitor
5 minutes, waking up again
and then re-fits, but
7850 fans are turning to sleeping at this time
particularly monitor sleep setting by 10 minutes;
After 10 minutes, but the card works continuously monitor fits
I hope what I'm saying I'm really sorry: ((
Are you running Windows 8?
Windows 8 will wake up your computer to run some tasks. Very annoying, especially because you expect the computer to stay asleep.
So, could this be it? A normally expected behavior, not a problem, and if you want to stop it, just configure Windows 8 to stop waking up to perform the chores, so it can stay asleep.
Wake the computer, or wake the monitor? I can see Win 8 waking the PC at pre-set time, but if the PC is running, there is no reason to wake the monitor.
Oh yes, my PC was waking up and the monitor would come on. Just WTF kind of behavior, I couldn't believe Microsoft would do that. Then again they bought Nokia and make Windows RT tablets...
