I've seen a couple of desktop systems lately that have ISA Creative Labs sound blaster awe32 or awe64 sound cards in them
that are acting up and I thought maybe some of you guys may know the answer.
When you start windows up they make a short blip of a windows start up sound instead
of the full sound.
You can go into control panel and into sounds and test the various sounds that windows makes
on certain events but you get an message that says the sound card may be in use (it's not).
You can play an audio cd and the sound card works fine.
You can remove the sound card device out of the device manager and reinstall and that doesn't fix it.
You can go into windows setup (windows 98se) and remove the multimedia section and reboot and then
go back in and recheck it and let the components be installed again and that doesn't change it.
I've seen 2 machines with this problem in the last 2 weeks. I put pci sound cards in each of them and
that "fixed" it but I know the ISA sound cards worked perfectly in a test machine I have so I assume it was
a windows problem.
Anyone?
of the full sound.
a windows problem.
Anyone?
