Hercules 9500pro cooling
piesang
80
I have a Hercules 9500pro, the stock cooling is very loud and not very effective (Thermaltake blue orb)
I want to buy the Zalman ZM80d silent heatpipe solution but I have a problem with my heatsinks.
On the back of my GPU there is a small heatsink as well as on the RAM. I don't know if I can safely remove these without damaging the card or GPU, can someone help me please.
AristoV300
1,380
To use the Zalman heatpipe the ram heatsinks are fine to leave on. There should be screws to remove the gpu hsf.
