???HELP???
ThaiStix
17
In my area the cable lag for shit!
i was wondering if i went out and bought a signal amplifier; then plug the cable into my cable modem. would i get any boost in performance?
any other suggestions for me to help my cable connex. bc it really sux! :( :|
ty
JackMDS
29,499
400
If the signal coming out of the Cable coax is s far bellow the Norm it will affect the quality of the connection.
If the signal is within the Norm boosting it will do nothing.
Fallen Kell
475
Get a packet sniffer and watch the amount of traffic that is going by on your cable connection. This might give you some idea of how much traffic is on your cable block. Each cable block has a limited total bandwidth, which is shared by everyone connected to that block. If the block is over-loaded (which is what sounds like is happening to me) there may be little you can do, other then complaining to the cable company to ask if your block can get its max limit raised, but hardware will limit how far that can be raised (type of cable backbone is in your area, either plain co-axle or co-axle to fiber, and network layout). There may be 2 cable blocks that run through your location, and you might be able to be switched to the other one if there happens to be one there. Aside from that, you don't have much else that you can do, other then DSL.
ThaiStix
17
you know what nevermind...
i just got emailed that DSL is avail.!!!!
WOOHOOOOO
no more LAG!!!!!!!!!!
MY OWN BANDWITH!!!!
WOOOOOOOO!!!!
thanks for your help guys!
