Hi all. i kinda new here and i just want to share a problem of mine.
My computer is a C2D E6300, Asus P5B, 2 gb ram, 7600gt 256, and 2 x 250 seagate sata
i have Vista 32-bit as my OS
sometimes when i turn on the computer, i get the message, "Insert System Disk. Reboot from system disk and press enter" or something like that. I tried restting a few times and still the same problem.
Now, what i did was unplugged the 2 HD sata connectors and plugged them in another slot (the board has 4 of them), and then everything worked perfectly.
However, over the past few months, the same thing happens again and again... and i just keep doing the same thing over and over (switching the connectors back and forth until it boots). this happened about 5 times this year, and i cannot pinpoint what is exactly triggering this problem.
What is the main problem here? is it my board or is it the hard disks? Please guys... im getting tired of switching the plugs over and over. i need to know what part is causing the problem so i can have it replaced (my PC is still under warranty)
Thanks a bunch!!!
Thanks a bunch!!!
