<< Usually removing the bios battery, setting the jumpers to reset the bios, set the bios jumpers back to normal, putting the battery back in resets the bios so that you can get back into your bios. >>
This is true, but I believe the problem Red Dawn is having is the fact that it is a laptop.
I am looking for the solution and will let you know if I am able to find it.
