As you all know, there´s an option that will make the computer to remember user id and passwords in different situations,for example hotmail,when you log onto the net etc.
Right now,this function disappeared suddenly for me.
I will have to write all the user ID´s and passwords manually now.
And another thing: When i have filled in the box with user ID and switch to the password box there is a delay in 5 secs before i can write.It sort of hangs up for a moment.
The same delay comes after i have written tha password down and pressed return.
I´ve heard about hackers using a prg that can store what keys i´m pressing,and later use that. That is what coming into my mind when the "delay" occurs. Like if a prg is storing up what i just wrote.
Well,hopefully thats not the problem.
Could it be a virus? (have no virusprgs)
Is there any way to fix this prob, so that I dont have to write all passes and ID´s manually when i log onto the net,using hotmail etc.
THX in advance!
THX in advance!
