help!
lighthse
I have a "great" time installing this alpha cooler...hehee
the clip is real hard to install! I used almost all my strength to get the clips hooked on thunderbird and wonder if I have damaged the chip....
Are that any systoms of a damaged amd chip? How can I make sure that cooler is securely fixed?
i'm using epox 8k7a+....i wonder if the bios temperature is accurate...
and where else can i check the temperature of cpu?
anyone can share what temperature of your chip you get with this cooler?
