HELP!!!!!!
FireStarOmega
60
What is the correct procedure to installing heatsinks?
Specifically Ram heatsinks. I have 2 geforce 3 cards and on one of them the ram heatsink fell out. I bought Artic Silver adhevise and I am wondering if that is the right way to go?
Thanks
Dark4ng3l
5,061
well read the instructions. I think you need to mix the arctic silver epoxy with the normal stuff. Than apply a real thin layer(make sure you clean both surfaces real well before you apply the epoxy) and glue the ramsinc in place.
panhead49
1,880
thats what happened to me.....gf3 came with one heat sink off......thermal epoxy (artic silver 2) spread thin or just in center of chip....put back on....back gamin!!
