Help!
cras4u
9
I have all the components installed, turned it on, everything is ok so far. I try to press enter, and my keyboard doesn't work! WHat could be teh problem? It's plugged durectly into the Mobo.
moonsite
692
USB or PS\2 keyboard? Did you plug it into the right one? If so, check with another keyboard first before you do anything else.
Captante
30,357
10,884
If its a USB keyboard & isn't being recognized, you most likly will need to find a PS2 keyboard to get you into the BIOS & under USB settings, make sure to enable "Legacy device support" or similar setting.
