Help!
CRH7386
Hey guys, I really need your help. I built my system like 9 months ago or so. Everything has been fine till now. I had my e8400 overclocked to 3.6ghz so it wasn't too much. I got Fallout 3 not too long ago and it was giving me lots of problems. It was shutting down and sometimes running really slow even on the lowest settings possible. I have SLI with 2 8800 GTS's (512mB) so it should run well. I uninstalled the game and was going to restart the computer and then reinstall it but when i restarted it, after i logged on the windows (Vista Home Premium), It gave me a BSOD, something about hardware error call your vendor. Also, when I hit the restart button, it was slow to do anything and gave an error that said windows explorer not responding and then restarted a few seconds later. I don't know if that will mean anything or not. So anyways, it restarted right away after the BSOD so I couldn't get much information so I tried restarting it again and I got the same BSOD again. So when I restarted again, I went into the bios and set everything back to default and only adjusted the settings for my raid so it could boot up windows. Then i restarted it and it still gave me the same BSOD. I tried to restart to look at the BIOS again and it just came up to the info page before the bios and said it was in safe mode and i must reset cpu or memory frequency. So I restarted again and ran in safe mode. Safe mode seems to work fine. So I defaulted the bios again and now when I start windows, I can log on and everything starts to load and after like 10 seconds it just freezes but no BSOD. I used Mem Test and the memory is good so I'm guessing its the CPU or motherboard. I'm not really sure what to do here since I don't have any extra parts to swap out. Any help would be very much appreciated. Thanks.
Have you checked all the fans are running? Is your case full of dust or anything else? What voltages were you using to get that overclock?
BTW paragraphs are good.
Ya, they are all running and there isn't a lot of dust. I usually use a can of air to blow it out every once in a while. I don't remember what the voltages were but they weren't anything crazy. I think 1.3 volts or so. It was a long time ago when I overclocked it.
Other people have suggested its the power supply. I did a disk check with the windows disk as someone suggested and there were no errors.
I tried using 1 GPU at a time and that didn't help either. I also did a system restore with the windows disk and no change so I'm guessing it has to be some piece of hardware.
