- Dec 18, 2006
- 2
- 0
- 0
Before I spend any more money replacing parts, I will see if anyone can help me here. I have a computer that is about 18 months old that I built myself. I never had problems with it until I installed a second hard drive. After about a month with a second hard drive, the computer would not boot with the second hard drive attached. Then, a few weeks later, it would not boot with the first hard drive attached. It WILL boot if only the dvd or cd rom drives are attached. (it doesn't matter if they are in the primary or secondary IDE slots) I purchased a new hard drive, installed it yesterday, and same thing. When I turn on the computer, all of the fans run and the MOBO LED lights come on. I have tried clearing the CMOS (with the jumper), replacing the battery, using the hard drive as a slave. It have an NFS7 MOBO with an Athlonxp 2600 processor. I have 1gig of ram (which shows up when the computer boots) I can only get into my bios with the hard drive not attached. ANY suggestions? I have a 450 watt power supply. It does not make any beeps with the hard drive attached. It just start up and then after 2-3 seconds, it quits. The lights on the motherboard stay lit, but nothing else happens. Does it sound like a motherboard problem? processor? power supply?? HELP! I have seven kids and only want to replace what I need replaced. Thank you so much for your help.
