HELP!
EBH
62
so i got some new fans today
i booted my computer and checked my mail and shut it down to install the new fans
so when i get new case fans installed and press the power button nothing happens
my motherboard should have some lights that come on, but i get thothing
i have a multi meter, but im a idiot and have no clue how to test to see if its the mobo or psu
it seems that ther eis no power coming fromt eh psu to even run the diagnostic lights on the mobo
i bought the mobo and psu in october
so pelase help me figure this out so i can rma the broken part back to newegg
the psu is a enermax wisper 2 460 w
the mobo is a biostar tforce 550 socket am2
any help is much appreciated
EBH
62
i just tried to jump the psu with a paper clip in 14 and 15 then turnign the pwoer supply on to see if the fan spins
nothing happens
if the fans do not spin up and then stop does that mean its a dead psu?
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
You were inside the machine, so first thing to do is carefully check all the molex connectors, the 20/24-pin connector to the motherboard, and 4-pin motherboard connector (if any), and any modular PSU connectors. Just make sure you didn't knock something loose. If it still won't boot, then tell us what PSU you have and what peripherals. Is it possible the additional/new fans draw too much power for the PSU?
EBH
62
psu is a enermax wisper II 460w
part number eg465p-ve fma(24)
when i tested it a second ago i removed everthing except the 24 pin and the extra 4 pin and still nothing
the fans wont turn no matter how i try to pwer it up, the lan port lights and diagnostic lights wont com on, and they should be on even with the computer turned off
im thinking psu is dead but i dont want rma until i was able to test it with my multi meter
how can i do that?
i have one sata drive, one video card, a cd burnder, a dvd rom, two case fans, a sound card and a floppy nothing is overclocked
i has been working perfectly until i installed the new fans, which i never got to try out cause it wouldnt start up
bamacre
21,029
Hope you didn't zap anything. :D
Did you make sure to ground yourself before touching the insides of your computer?
EBH
62
i used my grounding strap yeh
is there a way to test a psu if its taken out of the case and pluged into the wall with nothing attached to its connectors?
like a way to test if juice is flowing so i can rule out my mobo and validate that it is indeed the psu
EBH
62
so i plugged the psu into another computer and it wouldn't start it up
so its getting RMA'ed back to new egg tomorrow, i hope they have a replacement
only two months of minimal usage and that sucker went defective on me just for swapping out a pair of case fans
Atheus
7,313
I'm not sure, but as far as I am aware, a grounding strap is for handling static-sensitive components when they are not plugged in. I think using it while touching live components would be extraordinarily bad as it would make absolutely sure you provide a path for the electricity...
Can anyone confirm this?
SparkyJJO
13,357
7
Did you check the power switch on the back of the PSU?
Stupid question I know, but some people have actually forgotten about that little important switch back there.
EBH
62
the thing is that i unpluged everything on the back so i could take it out and lay it on its side
so it was not connected to any power source
then i waited afew minutes to let things dissipate
the case is a enlight mid tower so its got good access and such
if somthing got zapped it was such a slight charge that it tiped the defective psu over th edge
yeh i played with the switch in the back as well
the thing is that no matter what juice would not flow through the psu to anything
my guess is that it was defective to begin with and in pwering it down and placing two new case fans caused it to give up
maybe it was a bad cap or somthing i dont know, seems to me that a psu like this one should be a little more durrable
cause i basicaly put the machine together in october and never opened the case until yesterday
no burn marks were seen anywhere, and i use a ups to prevent surges to the machine
EBH
62
ok so they got the psu back at newegg and they are out of stock and the product is discontinued
they credited my account the cost of the part
so im now shopping for a new psu
i could use some recomendations
somthing comparable to a enermax wisper II 460w ATX psu
EBH
62
SeaSonic S12-430 a good choice?
my system is rather mild so it might be overkill
BIOSTAR TFORCE 550 Socket AM2 NVIDIA nForce 550 MCP ATX AMD Motherboard
Patriot 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory Model PDC22G5300LLK
Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
AMD Athlon 64 X2 3800+(65W) Windsor 2.0GHz Socket AM2 Processor Model ADO3800CUBOX
MSI NX7600GT-VT2D256EHD GeForce 7600GT 256MB GDDR3 PCI Express x16 Video Card
1 floppy
1 cd rw
1 dvd rom
creative audigy platinum ex
2 case fans
enlight mid tower
PSU that died, and is discontinued is:
ENERMAX Whisper II EG465P-VE FMA(24) ATX12V 460W Power Supply
mild overclock at the most i want to up the cpu speed to 2.2 from its stock speed of 2.0
Matthias99
8,808
Wearing a grounding strap while poking around inside a 'live' system... good idea. You can still deliver a nasty static charge to a system while it is running (although it should be somewhat more resistant to this, since it is in theory grounded through the PSU). Even if you do take a shock from something -- you'd rather have the electricity going through the grounding strap than your body.
Wearing a grounding strap while, say, poking around inside a 'live' PSU, or sticking a fork in your toaster... maybe not such a great idea.
EBH
62
thats why i unplug all the cables from the back of my machine when i open it up
i also let it sit for a few minutes so that it could drain of any charges
not sure, but if there was a static zap i think i would have felt it, and if it was so minor of a zap that i couldn't have felt it, then the psu is a pos imo
i already ordered the seasonic, it should be plenty i think
