Help!!
estew33
Hi All,
While waiting for a cpu rma, I decided to hook my JVC XV-SA600 DVD player that does hardware 480i and 480p to the dell 2001.
I'm only able to do 480i on the 2001 and when I try 480p I either don't get an image or I get a double image.
I have tried going thru the controls on the dell and I'm not able to see if i can set it to 480p.
I'm at a loss, any and all help/suggestions are appreciated
Thanks
Ed
Perhaps for some reason it doesn't like progressive scan? It has 1600x1200 pixels and a 60Hz refresh rate so theoretically you could display up to 720P on it. Does your DVD player upconvert to 720P? If it does maybe you should try that.
