Help!
i1o0i
262
I have trouble reinstall win xp on my old dell dimension and I'm getting error 7 which couldnt loaded some files on win xp cd, i think bad memory or bios might cause this error and then I tried windows xp home edition sp1 and its show some kind of uncommon error 'hard error' then I tried win me, its frozen during format and when I tried linux mandrake 10.0 and its worked.. so how can I format the hard drive on bios or dos and fix this uncommon problem?
mechBgon
Oct 31, 1999
30,699
One way to blank the drive would be to use DBAN, or use a utility made by the hard drive's own manufacturer to write zeros to it (and to test it, if necessary). Here's a page with links to some of the HDD manu's utilities: http://www.mechbgon.com/build/resources.html They're right at the bottom of the page.
