help!!!
dym
how to use truncated normal distribution to approximate the value of the renewal function?
Originally posted by: chuckywang
Truncated Normal Distributions have to do with probability. You're gonna have to be a little bit more specific.
here's the original problem:
For truncated normal distribution, originated from normal distribution with mean 4 and variance 1, approximate the value of the renewal function M(12), to 0.001 accuracy.
The original machine had a base-plate of pre-fabulated amulite, surmounted by a malleable logarithmic casing in such a way that the two spurving bearings were in a direct line with the pentametric fan. The lineup consisted simply of six hydrocoptic marzelvanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectivly prevented. The main winding was of the normal lotus-o-deltoid type placed in panendermic semi-boloid slots in the stator, every seventh conductor being connected by a non-reversible tremie pipe to the differential girdlespring on the "up" end of the grammeters.
Thanks, I DO appreciate it!!!
np :heart:
