Grimmy311
26
Current CPU Frequency: 2405MHz (267 x 9)
CPU Voltage: 1.40v
Temperatures: 32C idle stock voltage, mid to high 40's C under load at 1.60+v
Cooling: Stock HSF
Motherboard: GA-K8NS-939
Memory: 512 PC3200 Super Talent
Memory Bus: 166
Memory Timing: Auto
Memory Voltage: Auto
HT Frequency: 3x
Power Supply: Vantec ION 420w
These are my settings with my memory bus that low is this overclock even worth it?
stevty2889
7,036
8
Run some benchmarks and compare, but A64's are not that bandwidth hungry so running the ram at a lower speed won't hurt much.
Grimmy311
26
Current CPU Frequency: 2250MHz (250 x 9)
CPU Voltage: 1.40v
Temperatures: 21C idle stock voltage, low 30's under load
Cooling: Stock HSF
Memory Bus: 200MhZ
Memory Timing: 2 - 3 - 3 - 7
HT Frequency: 4x
This seems to be the only stable thing I can do without a BSOD can anyone give me some tips to keep upin her up? I tried bumpin the voltage to 1.6v and upin the HTT to 280 but I get no video )=
DAPUNISHER
32,482
33,552
You should read Zebo's guide Text I think you are going about this bass ackwards and that should provide you with the testing methodology necessary to get a good, solid, stable overclock :)
Grimmy311
26
Yes, I realize I am going high to low instead of low to high but thats just my impatient personality (=. I have it stable at the settings above and I scored a 16000 on 3DMark2001 SE so I am pretty happy with it for now but eventually I do want to get it up to the 2.4. I don't really understand the memory portion of overclocking yet thats why I haven't messed with that besides the memory bus speed.
Grimmy311
26
Current CPU Frequency: 2395MHz (265 x 9)
CPU Voltage: 1.40v
Cooling: Stock HSF
Memory Bus: 133MhZ
HT Frequency: 3x
When I am installing programs (i.e. World of Warcraft) I am getting alot of copying errors, I think it is because my memory is running too low. Anyone have any ideas?
Icepick
3,663
4
Running your memory at low speed won't cause those problems. That's a hefty overclock you've got going. Your CPU probably needs more juice to keep up. Try raising your CPU voltage to 1.425 or 1.45V.
Grimmy311
26
O.K. I uped the voltage to 1.425 and it seems to be running great. When I run Prime95 it gives me this error "FATAL ERROR: Rounding was 0.4999319195, expected less then 0.4" what does this mean? Also when I run any other cpu benching utility it never locks up and they say its fine. So whats the deal? Any help would be greatly appreciated.
Grimmy311
26
Well, I guess Prime was right, I jumped into a game and crashed after about 4 minutes. I can't get a stable 2.4 overclock :(
CPU Voltage: 1.40v
Cooling: Stock HSF
Memory Bus: 166MhZ
HT Frequency: 4x
This is the only setup I've gotten to run stable. Can anyone give me some pointers on how to pass this point?
