HELP
Bunnn
34
How do i update my Bios flash thingy
i have MSI K8n neo2 plat.
how do i jack up the multipler it stays at 10x max
i change the vcore volt. to 1.70 and it turns red warning me that it might not be stable...
how do i overclock it to 2.4
when i play CS it keeps on shutting off by itslef
How come my sound blaster live 5.1, when i test it, it says FRONT LEFT FRONT RIGHT and silencee.. for the rear two speakers, i've tried updating the drivers
my specs are:
AMD Athlon 64 3200+ winchester
MSI K8N Neo2 Platinum
Vantec Tornado helicopter fan
OCZ 1gb of dual channel 2-2-2-5
420w TT purepower ps
ts3433
2,731
A64s are top-locked--don't try increasing the multiplier.
When overclocking the HTT, you need to decrease the separate HT multiplier to 4x or 3x depending on how high the overclock is.
It's probably warning you about the VCore because IIRC that's a little much for an A64.
JBDan
2,333
my specs are:
Read two threads up called "Overclocking Guide"Read up on this and this will help you immensely. :) Take a look at this as well > http://www.insanetek.com/index.php?page=overclocka64 > very informative
