I am having some problem with my pc. I cannot access My Documents, whether from my user or other users on the pc. I have XP Home.
Whenever i click on my documents it says:
and i have checked and double checked that that path is correct.
I did however install Easy File & Folder Protecter 3.9
to hide My Documents from the other users only...it worked fine, untill yesterday...System Restore doesnt work for me, so thats another bummer. I am going to format my pc this week, but i dont want to lose my files...
I appreciate any help
thanks
The My Documents folder could not be found. Right-click the My Documents icon, click Properties, and then check the path to your target folder is correct.
thanks
