bmurray
29
Hello just bought this motherboard off ebay arrrgh. They said it was pulled from a working computer on closer inspection I found a capacitor or something that looked like it had been pulled out PCE 31 lower right corner close to sata connector could it have been for a reason or could i resolder it ? Was supposted to be a present it came with a amd 4400 x2 64. I know but Iam on disablity liver transplant money tight. any help would be appreciated.
Thanks Bill
so can I checked it without putting everything together it is a sli board?
I found the capacitor in the box, it is close to all connectors close to where the screw hole is in the corner.
mechBgon
Oct 31, 1999
30,699
Can you look at this picture :camera: and see if the capacitor is pictured there? If so, where exactly? If the capacitor is missing, then the seller should refund you (or the buyer), unless it was an as-is sale.
If it's the SLI board, it'll say right on it, as per that picture.
