Help!!
JJADAMS
I hope this is the correct topic to put under.
I have opened a file that requires you to select what you want to open with and always open with was selected. I selected the incorrect file and now it only opens in that file format. I meant to select regsvr32.exe Is there anyway to undo what I messed up? Thanks all for your help
Which operating system are you using?
I seem to remember that with win 98, you could hold down shift and right click, then select "open with"
