chicago
14
I have a ASUS p4c800 deluxe and I am get this message {Chassis intuded fatal error system halted} Why and what can I do to fix it. Thanks.
mechBgon
Oct 31, 1999
30,699
Look on page 2-26 of your manual, see item 7 there?
  • Turn the system off
  • Put a jumper across the pins they're showing in blue on page 2-26 item #7, if there isn't one on them already
  • Next, start the system and begin tapping the Delete key repeatedly until it lets you into the BIOS
  • Use your arrow keys to go to the Exit menu
  • Use the arrow keys to select Save Settings, and press the Enter key
  • Now select Save Settings & Exit, hit Enter, tell it Yes when it asks if you want to save, and it should be fine from there.
Hope that resolves it for you! :)
