I recently switched from the A8N sli premium to the A8N32 sli deluxe. I did some preliminary testing using just the stock hs to make sure all components were working and everything checked out fine. However, I just installed my XP120 and discovered that the heatpipes block usage of the first dimm slot. According to the mobo manual, if I want to use 2 dimms (which I do), I have to use the 1st and 3rd dimm slots.
What you guys and gals using on your A8N32? Is the SI 120 any better? I'd prefer something that give some cooling to the passive heatsink/pipes on board.
Thanks
Thanks
