I am having an unusual and hard out of resources scenario. When it happens, I cannot see icons or text correctly and in a gui pieces are entirely missing. Also I cannot launch most applications with a: this is not a valid win32 application error.
Restarting the PC fixes the problem but only for a short time. Also, when I restart, the restart prompt shows the 3 buttons, but the blue background is transparent as it cannot display it.
I noticed that running a drive search for a file is the fasters and easiest way to trigger this. It can be any drive and it will reach the out of resources state in several minutes.
I have uninstalled or disabled any monitoring software I had as well as my antivirus, avira free edition 2010 but is still happens.
I tried a basic drivers and services boot and it still happens.
I reinstalled chipset drivers, my hard drives, checked and moved my ram, and in all cases I cannot find any problems, but the problem still occurs.
I disabled ntfs last access update, 8.3 name creation and other ntfs tweaks and I have disabled zip and cab file support to see if that helped. The problem still occurs, it may take slightly longer to start.
I can use the PC normally for a day or a few as, long as I don't search, which used be weeks before.
I have not made any changes that I know of to correlate which this happening.
I am running out of ideas, and would love to find out a way to find the resource hog and fix it.
Thanks
Thanks
