endervalentine
So I got my shiny new X25M 80GB drive yesterday, everything went fine, updated the drive to the latest firmware, installed Win7 via USB, everything booted fine, and started running the stability tests and benchmarks.
Then I realized I didn't enable AHCI in the BIOS and it was still running as IDE. Updated a couple of drivers and rebooted, changed the BIOS from IDE to AHCI.
After that, I would get the BSOD on the Win7 splash screen and it would automatically reboot. Some googling seems like this would be the fix?
http://forums.guru3d.com/showthread.php?p=3508471
I didn't get a chance to try it since it was getting pretty late and I had to get some zzz's.
My 2nd problem is, I also tried reinstalling Win7 after enabling AHCI in the BIOS, but it would not boot through the USB HDD anymore, it would boot off the SSD instead. I'm 100% sure the boot order in the BIOS was set correctly since I had to do it with the first install.
Any suggestion on the 2nd problem, I prob. would want to go this route since it seems to be a cleaner method vs messing with the registry. TIA!
