- Jul 1, 2004
- 8
- 0
- 0
I'm trying to put together a new system and can't get both sticks of CorsairXMX DDR400MHz 3200CL2 to post. System just keeps trying to reboot, or if I'm lucky it will post the video bios and CPU speed, but then hangs right before memory check and I have to cut the power on the supply to restart. System boots with either stick in DIMM slot 1 no problem, but curiously won't boot with one stick in DIMM slot 2 or 3. Shouldn't this work?
I've tried different timing and speed settings in BIOS (F1 and F2d for Gigabyte K8NS-Pro) with CMOS set to halt on 'no errors', swapped video cards, etc to rule out conflicts, but nothing seems to work. Can't decide whether to RMA board or RAM.
Any ideas?
AMD Athlon 64 3200
2x512 Corsair 3200CL2
Giga-Byte K8NS-Pro
Western Digital 74GB 10000RPM
NV5900SE
Antec TrueBlue 480w
Any ideas?
AMD Athlon 64 3200
Giga-Byte K8NS-Pro
NV5900SE
Antec TrueBlue 480w
