Help with XP small home networking
bernse
I finally got XP installed. Pretty painless. The only thing that was slightly odd is that I had to install the Win2K V5 drivers twice, the first time I got a few errors. Second time did it though.
The only problem I seem to be running into now is setting up my home network. The other PC is running Win98SE. I have run the network setup on the 98 PC from the XP CD as requested, that seemed to go fine. It "seems" to complete fine on mine as well, but no matter what I do, I cannot see the other PC (the 98 machine) on mine (the XP machine). I get a brief bubble pop-up that lasts for a sec on my taskbar (XP machine) that says it can't resolve an address or something like that, then goes away really quick. I know the network card is working fine as I am on the net and the DSL modem is hooked up through the hub (both machines have that type of internet connectivity selected during the setup). Any ideas? Help?
Did you assign the Win98 machine an IP address on the same subnet as your W2K machine?
If Win98 is using AIPA (Automatic IP Addressing), you'll have to bind a second IP address to the NIC in your W2K machine to communicate with the W98 machine.
