Help with XP Pro running IIS server.
Spydermag68
2,617
99
I am creating a Local website that needs the .NET framwork 1.1 running on XP Pro
I have installed IIS server from the XP Pro CD. (Complete install)
I have check that I have downloaded and installed .NET framework 1.1 for XP Pro
When I start VS.NET and try to create a new VB.NET web application (ASP.NET). I get the following message.:
The specified Web server is not running ASP.NET version 1.1 You will not be able to run ASP.NET Web applications.
Snapster
3,916
Sounds like the .Net framework didn't register everything correctly. Try running the following:
C:\Windows\Microsoft.NET\Framework\v1.1.4322\aspnet_regiis.exe -i
And see if it works.
Spydermag68
2,617
99
Thanks Snapster!
Your solution worked!
The HD on the laptop is slowly in building the new ASP.NET project.
