I just finished reading the install guide for the xp-90 and I am confused. In the guide it states that to remove the stock RM I should use nail polish remover. I just removed the screws on the stock hm and gently pulled it and it came right off ( I have an epox 9NPA). It seemed there was no glue holding it on at all. Did I do something wrong? Do I have to take the metal backplate off the back of mobo?
With the stock HM off, do I just install the xp-90 hm with the two screws?
Also, with applying AS5 to a A64 (opteron), do I just place a small grain sized portion to the chip and then put the xp-90 on? Should I spread the stuff around the chip to cover the whole thing? Should I also apply it to the base of the Xp-90 too?
I know this stuff is posted in one place or another, but I just wanted to confirm. It has been ahile since the lasttime I built a computer.
Thanks!
Thanks!
