I bought a used X800pro modded to X800XT a few years ago and it can't run at the XT speeds anymore... I get artifacts in games/tests at those speeds, however if I knock down the clocks it becomes stable. I had to lower the clocks more and more as time went on and it got more damaged.
I was thinking about putting it in a spare computer. Should I just give up on the card?
It was flashed to open up the extra pipes, right? I don't remember how these mods work - it was so long ago. I was thinking about editing the bios, I want to keep the extra XT pipes open, but maybe bump down the default clocks a bit and, more importantly, reduce the core/ram voltage (I forget which I had to underclock to make it work fine, ram or core).
What do you guys think?
