Help with wrench on Solidworks
YoYoBabyYo
I am stuck on my wrench design. So far, this is what I came up with so far, but I am trying to get the arm aligned to the center of the wrench head arc surface. Is there anyway I can move the arm?
Or is there any better way to design the hex 24 wrench??
can't you just sketch the profile of it, then extrude it? i've never used solidworks, so i don't really konw, but that's how i would do it in pro/e
I could, but the head is 6mm deep while the arm is 3mm deep. When you mention sketching the profile, did you mean sketching the wrench as a whole on a plane?
yeah. That's how I'd start in inventor, you can trim the middle down later, once you get the basic shape roughed out.
