Help with wireless
HybridSquirrel
Im trying to set up a wireless network in my house. I have quest dsl at the moment and my router is wireless so i went through the xp wireless setup and it saved the info i needed onto a flash drive and told me to go stick it in my router, well my router doesnt have the standard usb plug but it has a port that says usb any ideas?
You need to login to your router and configure your settings to match on clients and the router. check your default gateway (ipconfig) and type that into a browser, that should be your router.
May be this can Help.
Link to: Wireless - Basic Configuration.
Link to: Wireless Security.
:sun:
P.S. Microsoft has few nice ideas that can help if the Hardware manufacturer would cooperate.
Unfortunately, cooperation is Not the name of the game in the computer commerce world. Therefore, the USB Idea is not widely utilize in the Wireless Entry Level market.
