jdogg707
I have a client that has asked me to install a wireless network at his business. He owns and operates a Marina, with a main office and a dock, about 400 feet apart, but have a straight line of sight between them. He would like to be able to share his DSL connection with the dock, to alleviate problems with the Dial-Up connection they are currently running to process boat licenses, fees, etc. I planned on a wireless router, using a high gain uni-directional antenna, to shoot the signal to the dock via a straight line of sight. At the dock a Wireless Access Point would be setup to receive the signal and then relay it to the computers at the location via wireless PCI cards in the machines themselves. My only interference issues would be the water of course and that there are telephone and power poles that sit at either side of the direct line of sight I have to the dock. I will also be encrypting the connection using WEP 128 bit, and will be using MAC address filtering as well. My question is, would this proposed setup work? And if so, what parts would you recommend as far as a high gain antenna, wireless router, and access point are concerned?
BTW, I do not have to have outdoor stuff, as the antenna, router, and access point will all be positioned in a way that can shield them from the elements.
