Help with wireless network components
gpw11
Hello, I'm planning on setting up a wireless network to share a DSL internet connection. The problem is that I don't really know which products I should be getting. Price is a pretty big issue here, so I'm thinking that 802.11b is what I'm looking for, but I was wondering how strong the signal is. I'm going to be having one PC in the (above ground) basement and one on the main floor. Would 802.11b be good for that? Also, I'm wondering if anyone could reccomend a good wireless router and wireless PCI card for this. I'm looking for good quality and fairly cheap here.
Thanks for your help.
RagingBITCH
17,618
There isn't a difference in range (that I know of) between 802.11B and G. The difference would be in the hardware itself by the manufacturer. (Different ones have different ranges) Since price is an issue and you want it basically to share a DSL connection, 802.11b would be perfect for you. G is only necessary if the main intent is to transfer files fast between computers.
Regarding cheap routers/PCI card adapters - basically just take a look in the local electronic store ads (BB, CC, Frys, Microcenter, etc) - since you're on a budget cheapest is probably the way to go for you. There's no discernible difference really between brands, although lots of people have different things to say about different brands. (I had lots of trouble with my Netgear. Right now I'm using a combo of Microsoft wireless router and Siemens USB wireless adapter)
Regarding the PCI adapter - your reception may suffer a bit if your computer is in an enclosed space. I'd recommend a USB adapter just because you have the option of being able to move it around for best link/signal strength. I don't know how your house is setup, how far away the wireless computer will be from the router, and what type of building materials the signal will have to go through (since it's going to a basement). In general 50ft would be the maximum length I'd recommend if you're going to use a PCI adapter. (This is just a general statement though)
gpw11
Thanks. Yeah, I guess 802.11b is for me then. The distance isn't too far at all. PRobably 20-25 feet at the most, and the signal isn't going to be going through concrete or anything like that (although there is tile). I'll probably be going wth something in the way of d-link or linksys. There's no problems using one brand card with another brand router is there?
Now, I don't have USB 2.0, just 1.1 would that affect speed at all? Personally, I'd rather go the PCI route, because my 4 USB ports are all pretty much in use (I could rearange some stuff and probably get an adapter for the printer though).
Are there any other issues to consider when thinking USB vs PCI?
Edit: And sorry, has anyone had any expiereince with the D-LINK DI-614+ ?
Thanks again.
JackMDS
29,553
430
20-25', buy what ever inxpensive hardware you can find.
For Laptop the regular PCMCIA is the best solution,
For Desktop (or tower case) USB Wireless Client Card should be considered as the preferred solution.
Why?
Wireless is depending on signal propagation.
PCI Wireless Client Card ends up been stuck behind the computer's case, resultant in obstructed transmission and poor performance. USB is connected to the Port with 2-3' cable allowing the Antenna to be placed above the System for better Transmission.
However a PCI card is a good choice when a powerful external Antenna is needed for long distance. Many Wireless PCI cards come with a removable Antenna.
