help with wireless dial up
Carver1
330
I am completely lost on this. I have searched th forum, google, anywhere else I can think of, and can't get my wireless connection to work.
I have my desktop connected to the phone line, through the modem. Then I connected the wireless 4 port router using an RJ45 cable between the NIC on teh desktop, and Port 1 on teh router.
My laptop is then connected using a PCMCIA card that came with the router. After install, the laptop shows that it is connected, but nothing transfers. The desktop also shows connected, and works normally.
I can't get the settings right, or don't know what the settings should be. I have tried to set the IP address the same on both, but get a conflict error.
Can anyone lead me in teh right direction? Or lead me through it if you have a similar set u?
All the sites I found are for setting up a cable modem. I can't find anything specifically for dial up.
Any help would be great!!
Thanks!
