- Jul 23, 2001
- 56
- 0
- 0
I made a few hardware changes to my system due to the old CPU fan burning out. Now I am getting the dreaded BSOD.
System is as follows:
A7V333 rev. 1.01
512MB Corsair XMS2700 memory
Geforce Ti4600
2-120GB HD in RAID Mirror
1-200GB HD for data & archives
DVD-ROM
CDR/RW
ZIP250
Firewire Card
NIC
SB Audigy
Basically, I replaced the CPU, took out the internal modem, and replaced the floppy drive with a mitsumi 7in1 Combo floppy & card reader drive.
I can boot up windows in Safe Mode, but when I try to boot normally, right after I log in, the mouse & keyboard lock up and then I get the following BSOD message:
A problem has been detected and windows has been shut down to prevent damage to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove and newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe mode to remove or disable components, restart your computer, press F8 to select advanced Startup options, and then select Safe Mode.
Technical Information:
*** STOP: 0x000000D1 (0x0000000C, 0x00000005, 0x00000001, 0xF86823EA)
*** fasttrak.sys - Address F86823EA base at F867000, DateStamp 3bfd8553
Beginning dump of physical memory
Physical Dump complete
The fasttrak.sys driver is for the onboard RAID...but it has never been a problem before.
I am almost to the point where I am going to reinstall the system, but I don't really want to do that.
I was posting in the CPU/Processors forum, but now that the processor seems to be working, I am bringing my problem over here in the hope that I can get some help.
Here is that particular thread with a little more background.
So if anyone can offer me some suggestions on what I should try before reinstalling, I would greatly appreciate it.
-Brian Blair
A7V333 rev. 1.01
Geforce Ti4600
DVD-ROM
CDR/RW
ZIP250
Firewire Card
NIC
SB Audigy
-Brian Blair
