- Apr 25, 2000
- 916
- 1
- 0
i know this isn't strictly on topic, but this box crunches seti, and that's about
it. Anyways, OS is Win2000. Was checking SetiQ and noticed it was overdue
so i turned the monitor on and it had hung up on reboot. The status bar on
the bottom of the page gets to about 90% and then just hangs. I tried
Safe Mode reboot, same thing. Tried reinstalling the OS, it loads the startup
files and then win it reads "Starting Windows 2000" it hangs.
I'm not sure of what to try next, short of FDisk ing it and putting a fresh install
on it. Is there any way i can save the two units it was working on? I took the
HDD out and put it in another system and backed up some misc. files and mp3s,
so the HDD is working fine.
Any ideas from you guys would be great, if not it's getting FDISKed tonight... i can't
stand it not crunching! (Win2K = Stable?)
System info:
Nothing new installed for over a month.
Tyan Tiger MP S240 motherboard
IBM 60GB HDD
thanks guys.
System info:
IBM 60GB HDD
thanks guys.
