hey guys... long time lurker, first time poster 😉
just received a 74G Raptor yesterday from the Egg. I tried to image my current boot drive (WD 80G) over to it but to no avail. tried using the Data Lifeguard utilities for the drive in windows... didn't work (i used drive to drive copy). it copied the info over, but didn't copy the paging file (i've since turned it off), and when trying to boot to windows on it, it said missing NTLDR.DLL i think. after that, i formatted it, then tried to use Norton Ghost 7.0 Enterprise. made a ghost boot disk then tried to do both disk to disk and partition to partition, but it closed the proggie out with an error both times due to the destination being smaller than the source.
so, last night, i tried to use the Data Lifeguard utilities again, but this time i told it to make the drive the new boot drive, then selected drive to drive... thinking this would work, i went to sleep. this morning, i woke up to find the comp frozen on the screensaver 🙄. rebooted and the controller wouldn't recognize the SATA drive :rolleyes^2:. turned her off, then swapped the SATA port it was plugged in to, rebooted and it recognized it :sigh:. checkdisk wanted to run and found errors like crazy for about 10 minutes and barely moved to 1%! i didn't have time for it to finish (at work now), so i rebooted and let windows boot up, booted up fine and explorer sees the hdd, but i can't access it, nor will scandisk run on it, nor will the format option work on it (crashes explorer if i try either one).
Question now is... what the hell can i do to fix it. hopefully i didn't crap the drive out, i'm assuming i'll need something to reformat the drive then try this all again.
Thx in advance for your time reading my plea for help/rant. sys specs are below if it helps.
sys specs:
Barton 2500+ @3200+ on NF7-S Rev2 latest BIOS
1G (2x512) Geil Golden Dragon Dual Channel PC3200
ATI Radeon 9800 Pro
*on the fritz* WD 74G Raptor
WD 80G 8M cache
WD 200G 8M cache
Audigy
burners yada yada
Windows XP Pro -> NTFS
sys specs:
ATI Radeon 9800 Pro
WD 80G 8M cache
WD 200G 8M cache
Audigy
burners yada yada
