- May 16, 2002
- 27,429
- 16,298
- 136
OK, what is the update the network script ?On the question of PPD, just crunch the OPNG tasks. That's the gpu version of OPN cpu task. They run faster on newer gpu cards and gives the highest PPD. You may need to spam the server and create multiple instances to feed your fast gpu cards.
On the question of stuck download, run a script to update the network periodically and wait.....
So, because they do not have capacity, they want people to just quit.About "optimizing" PPD at WCG: The OpenPandemics project cannot issue as much work as contributors are able and willing to process. (Or maybe they could; but then they would be unable to post-process all the results they receive.) Therefore, ask yourself if trying hard to work for OpenPandemics aligns with your own goals in your Distributed Computing hobby.
Regarding stuck transfers: The client will retry the transfers eventually, but the retry period is presumably rather long. That's a heuristic approach with the goal to avoid to congest an already congested server link even more. If this is not just transient but persisting, and you don't have means to help the project fixing it, then the only help to that project is obviously that a part of the prospective contributors backs out and leaves, until they have means to improve the situation substantially.
They sure don't want people to quit — what I really wanted to express is that if the transfer problems persist, then the workaround (for now) is that fewer people try to transfer, not that the same number of people try harder to transfer.So, because they do not have capacity, they want people to just quit.
Well, maybe that is what I should do, too bad IBM quit supporting this.
Thanks for this pointer; interesting info.Here's the latest from WCG on network issues. It sounds complicated to me anyway. https://www.worldcommunitygrid.org/forums/wcg/viewthread_thread,44311_offset,80#676758
Ouch! Is this new, or inherited from IBM's WCG?5-6 files per task
