- Nov 8, 2009
- 1,270
- 5
- 81
I have a EVGA 3090 XC3 - very happy with the card but of course it runs toasty, especially the VRAM.
I want to put it underwater.
I'm aiming for the EK Quantum Vector 2 as the water block and backplate -- this guy: https://www.ekwb.com/shop/ek-quantum-vector2-xc3-rtx-3080-90-abp-set-d-rgb-nickel-acetal
Questions I have are (prefer to stay with all EK parts):
- What radiator? I'm thinking 280 or should I go 360? How thick on the rad? This 280? -- https://www.ekwb.com/shop/ek-quantum-surface-p280m-x-flow-black
- What pump/reservoir combo? Is this smaller 120mm once sufficient on volume? -- https://www.ekwb.com/shop/ek-quantum-kinetic-tbe-120-vtx-pwm-d-rgb-acetal
- What fittings and tubing size?
Thanks for the help
Thanks for the help
